Aktuelle Zeit: 17.06.2026 - 16:05
[ 4 Beiträge ] |
Betreff des Beitrags: welche jaso mB öle gibt es? ...3 zzt Verfasst: 22.11.2019 - 06:47 |
motorradöl jaso MA nicht so ideal für automatik scooter mit trockenkupplung MB it is welche öle gibt es? hatte auf die schnelle nur das 1) motul scooter power 10w30 gefunden 2) kennt wer weitere? zb: 12,7 auf ebay https://www.amazon.de/gp/product/B00VG9 ... UTF8&psc=1https://www.lubrizoladditives360.com/un ... ma-and-mb/Zitat: MA vs. MB and the need for dedicated lubricants In the most basic terms, JASO MA and MB are differentiated by whether a lubricant is suitable for a wet clutch or not.
In 2006, in order to differentiate within JASO MA lubricants it was further divided between MA1 and MA2, with MA2 lubricants delivering the higher friction performance, enabling oil marketers to take advantage of evolving lubricant and additive technology for specific performance attributes. MB lubricants can be formulated with friction modifiers to contribute to greater fuel economy in Automatic Transmission (Scooter) applications.
Selecting the right additive chemistry for JASO MA and MB lubricants ensures the necessary performance in specific applications.
For oil marketers, selecting the right additive chemistry for each classification is critical for ensuring the necessary performance in specific applications. Communicating these benefits and considerations to end users is also important-while JASO MA lubricants are in fact suitable for all applications, MB lubricants may induce clutch slippage in motorcycles and must only be used in scooters. https://www.ato24.de/de/blog/oelwechsel-motorradZitat: JASO MB – Für Motorräder mit Trockenkupplung bzw. separat geschmiertem Getriebe (4-Takt-Motoren)
https://www.pkwteile.at/motoroel/jaso-mb1) motulMOTUL SCOOTER POWER, 4T MB Motoröl 10W-30, Inhalt: 1l, Vollsynthetiköl 2) castrolCASTROL POWER 1, SCOOTER 4T Motoröl 5W-30, Inhalt: 1l https://www.motorradreporter.com/artike ... so-mb-norm3) motorexMOTOREX SCOOTER 4T 10W/30
d.a.rous
Betreff des Beitrags: Re: welche jaso mB öle gibt es? ...3 zzt Verfasst: 01.02.2020 - 19:18 |
Das beste Öl das ich immer in 2T oder in 4T(10W40 TS) reingekippt habe ist von Procycle beim Louis. https://www.louis.at/produkte/motorrad- ... _view=gridKaufe immer 4 Liter, vor kurzem 15€ im Angebot, sonst 25€, 3 Liter für den Tmax 530(Nasskupplung), ein Liter für Honda PCX(Trockenkupplung)
Betreff des Beitrags: Re: welche jaso mB öle gibt es? ...3 zzt Verfasst: 01.02.2020 - 21:54 |
aha. na dann.
es gangad um "MB" specification hier speziell für automaten mit trockenkupplung
und dass es aktuell nur sehr wenige öle gibt
procycle ist nicht MB....
d.a.rous
Betreff des Beitrags: Re: welche jaso mB öle gibt es? ...3 zzt Verfasst: 02.02.2020 - 00:58 |
freakmoped hat geschrieben: speziell für automaten mit trockenkupplung
Na weils für die Automaten mit Trockenkupplung keine Rolle spielt, obs mit oder ohne MB!
[ 4 Beiträge ] |
