Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - Suche Toolbox Serie3
Hätte eine gute, kannst um 15 Euro haben. Am besten wär sowieso, Du kaufst mir gleich meinen ganzen Krempel ab, dann brauchst nicht immer extra zu suchen
Hallo, vielen Dank fuer die raschen Antworten! Ich bekomme aber nirgends den Dueseneinsatz - duesenstock fuer diesen Vergaser. Hat jemand von Euch eine Idee? Danke Lg Thomas
