Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - Härterer Stoßdämpfer vorne
Bin mit dem Fahrverhalten nun eigentlich recht zufrieden (zuvor eingebaut Feder war wesentlich zu weich, federte m.E. wesentlich zu stark ein!) , es wurde mir aber nun geraten bei einer stärkeren Feder zusätzlich auch einen härteren Stoßdämpfer zu verbauen, was meint ihr?
Habe dbgl. leider keine Erfahrungen, aber mal ein paar härtere rausgesucht, "Oldie-Optik" sollte möglichst erhalten bleiben:
Vielleicht könnt ihr ja ein paar Meinungen od. Empfehlungen abgeben: Macht ein härterer Dämpfer in Kombination mit der härteren Feder tats. Sinn und welcher ggf. (in Oldie-Optik)?
Betreff des Beitrags: Re: Härterer Stoßdämpfer vorne
Verfasst: 19.07.2012 - 20:18
ich habe in Verbindung mit der Stoffi Feder den FA Italia drin (Wg. Optik) - passt ganz gut (v.a. besser als die originale, aber auch als die probierte BGM); andere als die 3 hab ich noch nicht probiert.
