Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - Meine Vespa startet nicht mit dem kickstarter
Betreff des Beitrags: Meine Vespa startet nicht mit dem kickstarter
Verfasst: 12.04.2011 - 19:09
Hallo ich stell mich mal doof und behaubte das bei meiner Pk50Xl2 der Kickstarter nur so zum anschaun ist . Also hab schon gehört das die Vespa's eh leichter zum starten sind wenn mann schiebt aber ist das generel so oder stimmt da was mit meiner xl nicht sie startet nur beim schieben Kann mir jemand erfahrungsberichte zusenden Danke
_________________ Die Fehlenden PS werden durch Wahnsinn ersetzt !
Betreff des Beitrags: Re: Meine Vespa startet nicht mit dem kickstarter
Verfasst: 14.04.2011 - 08:12
Kann an deinem Kickstarterritzel liegen. Wenn es schon sehr ausgenudelt ist, dann greift es natürlich nicht mehr so, wie´s soll. Hast du denn einen Widerstand beim Kicken?
Um das Problem zu beheben wirst du ums Motorspalten nicht herumkommen.
Verfasst: 14.04.2011 - 19:06
Hatte das gleiche Problem bei meiner 200er. Startete nur sehr schwer mit Kickstarter, nach dem x-ten Mal. Manchmal spang sie an, ging aber nach 2 Sekunden wieder aus - so als würde man die Zündung abstellen. War der Motor erstmal warm gelaufen, gings besser. Bei Anschieben war sie, wenn sie nicht schon komplett abgesoffen war, sofort da. Zündkerzentausch half nicht, Vergaser war gereinigt und dicht, Lösung war eine neue Zündbox.
Verfasst: 19.04.2011 - 11:30
Ja das klingt genau nach meinem problem danke für den Tip werd mich mal schlau machen was die zündbox kostet und mir dann vieleicht mal eine neue zulegen
