Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - tacho spinnt
Registriert: 12.09.2006 - 08:49 Beiträge: 246 Wohnort: Wien
Von welchen Tachos sprecht ihr?
Wenns um alte geht, ich sag mal vor 80, hats meistens was mit
dem alten Fett innerhalb des Tachos zu tun, oder wie oben angeführt.
Natürlich kanns auch am Seil liegen - bei manchen staubst ja da schon
raus grüße
13
Mitglieder in diesem Forum: Google [Bot] und 25 Gäste
