www.vespaforum.at • Thema anzeigen - PK 50 XL to 133
Aktuelle Zeit: 17.06.2026 - 23:20
 Betreff des Beitrags: PK 50 XL to 133
BeitragVerfasst: 20.08.2018 - 14:50
Hello Vespa people...
I need some advice..
I have pk 50 xl 1989 that I would love to upgrade to Pollini 133
My plans are to have set up like this:
24 Dellorto carb
Pollini right hand exhaust
Pollini cylinder and piston
2,56 primary gear...
What else do I need to change or do??
Thank you
 Betreff des Beitrags: Re: PK 50 XL to 133
BeitragVerfasst: 23.10.2018 - 08:05
Bajadera hat geschrieben:
24 Dellorto carb
Thank you
You have to change the crankshaft to a type with 51 mm stroke. For this you have to split the engine. As I see you want to install a 2,56 primary gear - for this you have to split the engine anyway.
BeitragVerfasst: 28.10.2018 - 18:24
Thanks
:respect:
