Deprecated: Function set_magic_quotes_runtime() is deprecated in /home/vc001ged/www/home/forum/common.php on line 106 [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/session.php on line 885: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 918: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'Europe/Berlin' for 'CEST/2.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3424: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3426: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3427: Cannot modify header information - headers already sent by (output started at /common.php:106) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 3428: Cannot modify header information - headers already sent by (output started at /common.php:106) www.vespaforum.at • Thema anzeigen - grosser konus... kleiner konus...
wenn bei der Mutter am Schwungrad ein 17er-Schlüssel passt ist es ein kleiner Konus. Passt ein 19er ist es ein großer. Bei der Spezial ist es normal ein kleiner. Mfg Mikasa
Falls ich mich nicht täusche ist bei Smallframe auf der Limaseite immer ein 20/47/14-Lager verbaut. Ausnahme ist die ETS-Welle, da brauch man ein anderes Lager und einen anderen Dichtring.
Betreff des Beitrags: Re: grosser konus... kleiner konus...
Verfasst: 22.09.2010 - 20:29
naja, unten bei den fahrzeugen steht 50 special, also kleiner konus, wenn motor orischinal. aber sach mal, hast du keine schiebelehre? währe ne gute investition, wirst immer wieder brauchen
Mitglieder in diesem Forum: Google [Bot] und 9 Gäste
